Yep. "Sheepsfoot".
What's a half hawk?
The "half-hawk" knife has nothing to do with Lambsfoot knives, beside for the fact they both sport straight edged blades.There is also a "Lambsfoot", however, they are not the same as a "Sheepsfoot". I believe the Lambsfoot blade has a taper, whereas the Sheepsfoot does not. From what I've seen here on the forums, the Lambsfoot blade is also longer than a Sheepsfoot.
All of the "Half Hawk" knives I've seen have a Sheepsfoot blade, and a different handle profile from the Lambsfoot knives I've seen.
Also, a lot of the Half Hawk knives (for example, those by Rough Rider) have a secondary Pen blade. However, the lack of a secondary blade doesn't mean it is a Lambsfoot. My 9 dot Case 031(?) is a single blade Sheepsfoot.
I am not an expert on the Lambsfoot. That person would be Mr.Jack Black .
EDIT: There is also the Wharncliffe blade, but it has a "stabber" point than the Lambsfoot and Sheepsfoot blades do.
As far as I know, Rough Riders are the only ones to sell a knife called a Half-Hawk. I wonder if it's so named because it is built on the same frame as the Hawkbill Pruner.
The more I think about it, the name makes sense. It's 'half of a hawkbill' I've seen a number of old pruner blades that have been broken and then reground into sheepfoot blades, the new sheepfoot comes out a little wider toward the end.
So RR made up a new traditional pattern?
...The RR called a half hawk I would think would more appropriately be called a sway back jack, or because of the larger size a loom fixer like Case's 6217.
I have little respect for the "half" labels that spring up when talking about knives;
to whit, "half-whit!!![]()
