No oxycontin, I meant what I said, a new traditional pattern. This knife is definitely traditional. My search for a non-RR half hawk knife turned up zero. Unless Planterz or someone else finds one that predates the RR model, then RR made a new traditional pattern. The posts above don't agree on exactly what it is, so it must not be an old traditional pattern (to distinguish from new traditional pattern, no redundancy intended).
I wonder who invented what...
and so on, &so...could add a dozen (at least) more, from France, Germany and Spain... Nothing new under the sun.
Let me try it this way. Is the blade in question called a Sheepsfoot even though the spine and belly are not parallel?
This blade has been mentioned. The knife is called a Loomfixer. Maybe someone can explain how that widened blade is used. I don't know exactly - it is easy to guess it is used to fix the warp or weft on a loom. Does anyone know for sure? It is not a sheepfoot.
Since a Sheepfoot's primary use was to trim hooves to keep sheep from getting crippled, a widened blade would be a detriment, making it harder to turn around a hoof as you trim it.
In fact I suspect a Lambsfoot blade makes a better "sheepfoot"!!
Go figure!!!![]()
Ha ha!! I like it!!Why did he write "oxycontin" and why did he colorize it?!
@waynorth How about a quarter congress
The knife from RR is a curved jack or "New England Whaler"...some of the oldies were etched with that name. Very old pattern.
A swayback jack has a more extreme shape and has less heft to it. It is a smaller knife. The swayback jack from Tony Bose is stylized and a bit more moderate in shape to better suit modern tastes. To my knowledge nobody currently makes the knives with the same extreme shape of the oldies.
This is an example of a swayback jack
The knife on the bottom is a "New England Whaler". Tony's stylized design is somewhere in between the swayback and the New England Whaler. It is a lighter knife like the old swayback but the shape is more moderate.
