It was a bit of an interesting evening. I did the rounds of my local hardware stores and managed to get a full set of ball-peen hammers. 2oz, 4oz and 8oz:
I then took a scrap of G10 handle material, along with some of the new 304SS pin stock that I bought and tried each of the hammers out:
The handle material is Black G10 laminated to a thin spacer of ruby red G10. The red is translucent and you can see that it's already showing up the crazing on the 8oz test pin quite strongly.
I then ground the pins back to have a look what I'd ended up with:
As you can see the 4oz and 2oz hammers made it much easier to avoid crazing on the black G10, but clearly the red is very sensitive to this issue. To date I have never used the red as anything except a liner so that's not a huge problem.
I then took the test piece to the disk grinder so we could have a look inside the block to see how the pins deformed:
If you look closely you can see that the pin peened by the 8oz hammer has actually expanded along it's entire length, you can see crazing all the way through in the cross-section. Not ideal. It's also obvious that my counter-bore technique is definitely off the mark. Those pin ends want to be conical and they're crushing material out of the way to get there...
After trying all that I started seriously looking at the mini Corby rivets that I had in my drawer. I started messing with them and some scrap handles a bit more and I'm feeling more comfortable with them. I'm going to do a strength test on them tomorrow using some scrap handle scales, and a scrap O1 blade and see how that goes. If they're strong enough then I think the extra expense may pay for itself with much less stressful glue-ups, and also much reduced chance of scrapping a knife due to aesthetic handle issues at the last moment.
Thanks to everyone that suggested the rivets, it's reassuring to know that so many people like them!
I'll post a thread tomorrow about testing the Corby rivets...
