- Jul 15, 2009
If I understand you correctly, this sounds more like a lapping/flattening process on a wide surface (the inside face of the shears), as opposed to sharpening/stropping a very narrow bevel/edge. I assume you're pressing the inside surfaces of the shears flat against the glass while rubbing/polishing with the compound? If so, it makes some sense to me. This would be the same (essentially) as lapping a stone with compound on a flat, hard, smooth surface, where the compound gets underneath and can do some real work.
As for sharpening/stropping a knife on glass, where only the very edge, or a narrow bevel is making contact, I'd think using the compound on glass wouldn't be very effective, without having some medium to hold the compound as the edge passes over it. Otherwise, most of the compound would simply get 'pushed around' on the glass (I'd think).
Not being critical. Just checking if I understand what you're trying to do. It's an interesting topic.
Obsessed has it exactly right here.
Frosted glass... Tell you what. I'll try the frosted glass thing tomorrow. I'll sacrifice the back of one of my Shapton glass stones to do it. I'm not afraid to try something that might be stupid. It's just so crazy, it just might work. I'll use one micron HA diamond spray and two identical shears. I'll use one of the pairs of shears on plain plate glass as a control. I'll report back tomorrow or Monday after I'm done.
