- Jul 22, 2009
I did. Didn't notice any alterations to the edge, in appearance or sharpness.If the edge is already mirror polished try the film bare. That's how I discovered it.
jimnolimit mentioned offset printing blanket material which I think may have some merit as an alternative to leather. More often than not leather is not required when using compounds. A good honing leather should stand on it's own.
If any of you folks are planning on experimenting with that material I hope you post your findings.
I do a lot of leather cutting, I'm thinking of using it as a cutting mat similar to the ''self healing' types that can be kind of pricey. I'll let you know about that.
Can't thank you guys enough for your support,
Keith
hopefully i will be able to make the strops by the end of the weekend, then i need to get some sprays/pastes to test. do you offer a 3 micron diamond spray? im looking to test:
1. 3 micron diamond
2. 1 micron diamond
3. 1 micron boron carbide
4. 0.5 chromium oxide
i will probably do my first test on my newly acquired (used) straight razor. i plan on taking the blade from re-bevel to finished shaving edge. i will definitely make a thread showing each step under my microscope.
Hey Keith, is the boron a new mix too or would it be the same as the liquid I have? The 12 carat 1 micron diamond still seems to work faster with a better final polish, the boron is not far behind but there is a difference.
And +1 on the horse leather, mine seemed to need some break-in time but after a few uses it started to yield some amazing results. Works quickly too.
I have one film left still in the bag, when I get a chance I think I'll test it again. I have a few thoughts on the difference in compounds but nothing too crazy
Thanks for the tip, I got a hanging strop that might work for :thumbup:
