I've been meaning to pick up one of those blocks in "fine" ever since I saw Ed Caffrey recommend them for things like finishing guard faces. At first I thought they were just the typical sanding sponges, which threw me off a bit as to why he would use those.
It's funny, I usually don't have much trouble getting a clean finishing pass, but one of these would've been perfect for my most recent santoku. It was ground in a bit of an odd geometry (for me) where I first flat ground about 2/3rds up the blade, then I convexed the first 1/2" or so up from the edge, and then I went and blended the shinogi with the upper flat to give it a bit of a convex as well. It's all subtle enough to appear flat, but I had a heck of a time trying to cover the entire surface of the blade with all the different angles; I tried all kinds of material for backers such as rubber (gasket), wood, paint sticks, some firm type of "foam" cut to shape from large alphabet letters that I think once belonged to my niece lol, and then I even tried with some softer leather (which I never use due it is softening up edges and lines I don't want softened), but that started to round over the heel while trying to get the ricasso with the same pass after having to take so many passes, as well as the tip. I was
finally able to get it to where I could call it good, but I'll be picking up one of those blocks for sure in case even I run into a similar problem.
So anyway, I just wanted to say I feel you're pain, Dustin, as this was the hardest time I've had getting a clean hand rubbed finish on a blade, and it was fairly recent as well so the headaches are still fresh in my memory lol.
~Paul
My Youtube Channel
... (Some older vids of some of the older knives I made)[/I
