I wrote above: the differance between 10 and 11 degrees are 1/1000 part of 1 mm in thickness of the cutting edge. That is 1 my differance.
If I use a 25 micron sharpener - what is needed to remove 1 micron material from the cutting edge?
To understand how sharpening work - we must go down to this = 1 my = 1 degree on the cutting edge. When we understand this tiny thing - we can start to discuss how wobble Ada up with the number of wobble, how big the wobble are - and how many sharpenings it takes to change an edge.
Yes HavyHanded we have had this discussion before I have discuss this many times during the years.
I like that you agree about the Basics. Then we can start to discuss the 1 micron more, or less, material in the xutting edge that means 1 degree change if 1 side of the edge.
Chris A,
No you are more wrong then correct. My tool Chef have a fixed distance between the cutting edge and the pivot point = Chef can be adjusted for different blade width - and the protractor shows the correct degrees for all blade widths.
The distance 28 cm makes that 25 millimeter change between the cutting edge and the pivot point is 1 degree change if the edge = if the distance change to 25,5 cm (from 28 cm) the edge will be 1 degree steeper. Your principle are correct - but Chef allways use 28 cm distance and the blade width do not matter, you will get the wanted degrees with Chef. Chef was the first sharpening tool that are asjustble for different blade width - and that was the solution for the built in peotractor that Chef also was the first sharpening tool to have. If I remember correctly, Chef was first with 16 functions, this was two of them, convex edge sharpening was a third, and so on...
Removing burr. When a sharpening tool is exact and give 100% flat edges - the burr also gets an exact thickness - the same thickness all along the edge. This means that the burr are easyer to remove.
When you sharpen by freehand, you wobble = the xutting edge will NOT be straight, the cuttingedgecutting WILL get thinner, and thicker, parts - and the burr also. This makes the burr harder to remove - and when you have renove the burr, it WILL give flat oarts on the cutting edge - ABS thise fkat parts have sifferent widths. This is possible to se with reflexion light, it looks like dots, not as a line. When you take this flat surface away, you must sharpen the edge two surfaces compleatly together again. (Sorry I lack words here and I cannot describe this correctly).
Once again, we are now discussing the messuring My and less,= less then 1/1000 parts off 1 millimeter things, things we cannot meassure our selfs.. But ut starts there - and adds up.
Yes, it is important to understand freehand sharpening - and different sharpening tools and what they can perform. Here is a big lack of knowledge - and most people think that all tools workshop same - when it is a very big differance between how the tools work and what they can perform.
There is one thing that works the same - if the knife are locked in its position on the grinding table and cannot move - and if the sharpening angle are locked to the wante degrees - it cannot be anything else then 100% flat edge. That follow the law of fysics. Do not argu about that
Tools that so not lock the knife on the grinding table or not lock the sharpening angle will not give 100% flat edges. This is facts.
Then, all people do not need 100% Fiat edges - but that is another discussion.
So, we have come a long way now, you guys accept that there is wobble innfreehand sharpening - and no wobble in a sharpening tool (if the tool are correct made and stabile). I like that. Now can we go forward and understand the consequences of this - and go down to my, the deigned water that destroyed stone - and that the first drip starts this process.
I like that we discuss as friends and that we are polite. I enjoy this discussion.ä
Thomas
Chris A,
Thomas
