Oh yea... this is a real unique way to keep kitchen knives and all sharp.  I have been chastised by some  on the shaving forums for putting a straight razor on the 1000 grit,but you know what??  That 1000 grit doesn't even mildly heat the blade, nor does it remove temper.  I have shaved with my straight razors after getting them on the 1K belt, and then worked 4K, and 8K on the stones.  It cuts hair easily on 1K but the stones polish off the edges just a tad bit more.  I've taken a straight razor from totally dull, meaning I purposedly dulled the edge, and then using the 1K belt put an edge on it that shaves arm hair.  From there, go through the stones and maybe even a balsa wood strop I made and put Chromium Oxide on it.
Another use, is I took up wood lathe work, and it can really put an edge on the wood cutting tool, and I do mean fast. I don't go up to 1000 grit with them, but stick with the coarser grits and really cause the wood chips to fly!!
I polished the body on the leather belt of the 1X30 belt sander.
