Amen to that. I did wonder if it was just me and my machine that it happened to. I really get it with the finer grit belts 500 and above. I really dislike doing the shock dance, and for this reason I mainly only use my belt sander now for coarse work.Fall and dry air are on the way. Prepare for some static electricity on your sanders. Seems to get me most often when I use the SiC belts, but then I use those belts most often.
You're probably over stropping. It should take just a couple passes after 9 microns to remove the wire edge.
Frankly, I think the focus on very fine pastes is a bit of overkill. You can probably do away with the pastes altogether and just use the natural abrasive qualities of the leather for the final strop. On the other hand, I always found that I did fine with just a generic white compound.
There might be a difference in focus among us. When I sharpen a knife, I do so with an expectation it will be used for cutting real things, not trying to sever free-hanging toilet paper or a silk scarf falling through the air. Too fine an edge is a weak edge; you can make a knife cut toilet paper but go instantly dull when the edge scrapes against bone.
Separate the academic interest from the practical utility. Both are worthy objectives, but I'm inclined to be referring to just one of them when you might be looking for the other. I want my edge to cut through chicken bone and still be as sharp as when it started.
Try lowering your crosshairs a little and see if that helps.
Ray,
I've got two surgi-sharp belts, and 6, 2.5, and 1.8 micron SiC paste, and 1.0 and .5 micron diamond paste, and .5 micron CrO.
But I guess it's just my technique, or lack of experience, but I find the leather belts EXTREMELY difficult to work with.
Usually, after sharpening on sanding belts, I power strop, and then have to use the 9 micron belt again and then strop again.
I almost always succeed eventually, but sometimes I have to sharpen the blade 3 or 4 times, due to the leather belt dulling it.
I guess I just need more experience!
Ben
Once you've rounded the edge, it's a lost cause. You probably need to go back to a 20 micron belt for the redo.
You said you did write on this subject. Would you please post the link where I may view it. Or does anyone else know how I might find same.
I bought a HF belt sander and met with failure so I gave up !
Thanks,
armilite
I agree, but remember that knives have been mirror polished with white compound. It may well be that using the platen with the leather belt could help resolve some of the tendancy to dull the edge during stropping.
A new question for this thread. Any of you that regularly sharpen on a sander find that the edge near the plunge grinds ends up with a different shape, sort of recurved? If so, do you know how to stop it from happening?
