does the HF motor get hot after 10 -15 mins of sanding?
My 4" x 36 belt sander gets very hot. Too hot to place hand on motor after 15 mins.
No idea if its normal.
i got two motors which are bought new that have this problem? does it mean that they are of inferior quality? They are made of china. :grumpy:
I stopped using the leather belt and loaded up my used 1000 grit with green polishing compound. I really believe that I am getting a better sharper edge,. I think the flapping of the leather belt prevented me from optimizing my edge,
Thom?? You out there??
That's an accusation I hear daily.![]()
Let me suggest a couple things. Fresh coarse belts can be problematic when doing fine work. There are actually two problems. The edges tend to cut more aggressively than the middle so they can cut into an edge before you know it. Use a rock or better yet a piece of brick to break the edge of the belt before you use it. Just hold it against the edge of the belt for a short while as it's running. Secondly, you can use a piece of mild steel or something similar to break off the coarsest parts of the abrasive across the belt. Just a light touch of a mild steel bar (Home Depot sells mild steel bar stock) held across the belt for a couple turns tames the beast quite a bit and makes that initial sharpening pass a lot less dicey.
I usually keep some well used belts around for just that sort of thing. I also have a wheel dressing stone (used to flatten grinding wheels that I think I got from Brownells) for breaking the edges of fresh belts when I'm working on smaller blades.
The idea in using the rough side is that it holds the compound better, i use the smooth side. I spray with WD40 and then charge with green and it holds better.
