- Jun 11, 2006
I'm having a slight issue that I never even considered befor I started heat treating for other people. The issue is measuring hardness on blades that have some decarb. I don't seam to have a problem with the 1084 I have done but I did a 15n20/1095 blade that had a good soak and I could not get an accurate hardness reading. I know it was good as I heat treated a 1084 blade at the same time (one blade at a time) and it came out screaming hard. But 1084 did not get the soak time. So my question is this. I want to be able to provide accurate hardness measurements to my customers as well as test and make sure there desired RC is hit after tempering. The only way I can see to do this is to remove the decarb from a small spot on the tang and test there. I'm hoping to add nitrogen to my oven in the future but until then I need some sort of solution. Any ideas, thanks guys.
