Hatchet in 3V: Where can I get one?
thanks ai......
Thanks for the appreciation! 😃
Yeh, I threw my unstructured thoughts into Gemini and asked it to make them into a coherent and well-formatted answer for the forum, in my previous message. It ended up more verbose than I thought, but I didn't have time to refine it further. Apologize for that. :D
Now I'm writing myself to avoid further fun. 😁
Now leaving the AI aside, CPM-3V is not used in axes because it is not forgeable and because other steels are better than it for the application.
Based on knifesteelnerds.com, by toughness, L6, 1085 and 80CrV2 are rated to an 8 out of 10 (probably based on a charpy or similar test), CPM-3V to a 9, while 5160 has a 9.5. S7 shock steel is not there, but I know it has a slightly lower impact resistance and slightly higher lateral strength than 5160, so it's probably also close to a 9.5. Now here is the interesting point: Hardness also has a play in this and there are some nice charts with different steels at different hardnesses. CPM-3V at 58 HRC has around 41 ft-lbs toughness (i.e. resistance to chipping or breaking when impacted). At the same hardness of 58 HRC, L6 steel has 45 ft-lbs, while 5160 has a toughness of 45 ft-lbs at a hardness of 59.5 HRC!!!. That means that practically all these steels have better impact resistance than CPM-3V if used at around 58 HRC (the generally prefered hardness of high performing axes). The only advantages you'd have over these steels, if using CPM-3V in an axe, would be additional wear resistance and some extra corrosion resistance. The fact is that wear resistance is not valuable in an axe. Its main usage is to cut by striking. Even if you use it to do some feather sticks in a survival situation, that would still be done via push-cutting and not slice-cutting or friction-cutting. The shape of a hatchet is simply pushing you towards push-cutting and strike-cutting, not slice-cutting (as you do with a knife). So you get no extra-value by having CPM-3V there. CPM-3V is excellent if judged by its balance of wear resistance and impact resistance (which are highly valuable in a knife). If you need one of these properties more than the other, there are other steels that fit better. In applications like an axe or hatchet, where friction-cutting occurs rarely or not at all, what you need is extreme impact resistance at high hardness (i.e. combined with extreme deformation resistance). The optimal steels here are the ones I mentioned: 5160, S7, L6 followed by any carbon steel with a carbon content between 0.6% and 0.8% (especially if it has some extra small amounts of added silicon or nickel). The most appreciated axes in the world are using one of these steels.
Well, I did learn something important about steels like 3v in that they cannot be forged.
I'm going to go out on a limb and say you already knew this, in your heart of hearts.
I learned something terrifying though... AI has learned necromancy.
Supposedly, Lon Humphrey forged some 3V kepharts some years ago. If I recall the interview or product highlight correctly, he said, "never again!" as it was far from easy.
Can't imagine someone trying to forge an axe from 3V.
Well I love me some 3V and the thought of a nice axe or hatchet made with it is cool as can be. But....
While I never lived as far north as Ontario, I did live for 5 years on the side of a mountain deep in the Rockies about 40 miles south of the Canadian border.I had to cut quite a lot of firewood during the to heat our cabin and cook with in the long winter. And I split literally tons of wood with a 40 dollar Fiskars X27, liked it so much I bought the hatchet and took it every camping trip. But in my old toolbox of things I amassed over many years was a cheapie wal-mart hatchet from 25-30 years ago, dull as could be and with that store bought rounded "edge" that bounces off wood. One day I decided to try re-profiling it, so I took it to the sander and went to work making a new profile, then sat a while with a puck making a new nicer bevel. It worked just fine after that for a porch hatchet to split kindling from the chunks I kept on the porch. So I never have bought an expensive axe.
