Are you really not getting this? Seriously? For the last time and read it slowly. Since my experience is my experience it doesnt mean it didnt happen because you had a different result occur in your experience. I stand by my claim that I have never had a bearing headset fail in my years of riding bmx nor my peers. YOU did. So because you did my experience cant be true? And all of a sudden you take my one single instance of personal experience and turn it into a blanket statement claiming I said that bearing headsets dont pit? I said that MINE DIDNT and I didnt even use a specific term I simply said mine didnt fail. If you dont know the difference between a single personal experience given as an example and a generalization I dont know why I am even bothering debating with you. When you take something I say and twist it and put words in my mouth then what is the "engineering" term non engineers use impress others to describe it? I only ask because that is the term I want to use so you dont get confused and twist my words further.
I missed your other long rant. My apologies.
Look, I think you are doing some of the things you are accusing me of. So let's both stop whatever that is.
Specific to your posts:
A race is whatever the balls ride on. It doesn't matter how it is made, out of what, or anything else. "Race" is the word for the surface they run on.
"Work hardening" is a general term for what happens to some metals when they are deformed. On some metals it has a negative connotation, like aluminum. On other metals it adds strength. If there is a claim that IKBS makes the race surface harder, I'd like to see that. I don't know if that is going to happen or not with 6/4 titanium, and I have reason to believe it will not. But I'd be happy to read anything you might have specific to 6/4 and roll/deformation hardening. I could not find anything about it myself, which doesn't surprise me because titanium is not a material that is much used for high wear or compression, like IKBS is using it for.
There is no debate that you can form a race surface through plastic deformation in 6/4, and that a steel bearing will dent titanium. What seems to be the disconnect is that "dent" and "pit" describe two very different effects. A pit is a surface fracture that usually occurs from abrasion on hard surfaces - like walking over dried mud. "Denting" is like walking over wet mud. Very different.
Unfortunately, a preponderance of positives doesn't disprove a negative. Not observing a failure is like not seeing air. Permanently damaged 6/4 races in knives may not be a problem at all, and if Archie's scoring is the only example ever, than it isn't a problem. And I haven't said it is a widespread problem - I've just said that it all seems pretty sketchy considering that no other industry would make a bearing race for steel balls out of anything with a Rc in the low 30s.
The main thing that bothered me was this statement:
My example of bicycle headset bearings was only used because of my personal experience. But you having a differing experience doesnt automatically discredit my example. It simply means you had different results.
It really doesn't mean that. It means that your sample size was too small, and the experience of all bicycle users would disprove your sample. Pitted headsets aren't a weird thing I saw, it is a normal wear item known throughout the sport and industry, which I unsuccessfully tried to educate you about. If you would prefer to believe what you didn't see was just as valid, I don't know what to say to that attitude.
