I didn't origionate that perspective, I read it from Ben Dale. Since you continue to ignore facts and logic and want blind faith in names then this discussion isn't productive.
-Cliff
So kids I went and did a little looking on my own for the website of Mr. Ben Dale...
http://www.edgeproinc.com/Instructions.htm
May I quote Mr Dale?
"■ BRING THE EDGE TO A BURR. Continue making equal passes down each side of the blade. When the two sharpening cuts come together at the edge, the metal breaks down and forms a BURR, which can be felt by drawing your thumb across and away from the edge on the opposite side of the last pass. As the blade moves across the Blade Table, you want it to remain parallel to the end of the Blade Table.
■ CHECK THE EDGE FOR A BURR each time you switch sides. The BURR will begin to form in some areas & not in others. Concentrate in areas with no BURR and lightly pass over the areas that have a BURR. When you have an even BURR down each side of the edge, switch to your finish stone.
■ MAKE A FEW PASSES with your finish stone. The BURR will become much finer.
■ REMOVE THE BURR. Wipe the stone and knife clean of the stone grit. Make one or two passes down each side of the blade with NO PRESSURE on the Stone, just the wight of the Stone Arm. DO NOT HIT THE STOP> Only make one light stroke in each area of the blade. Check to see that the BURR is gone. If you use too much pressure or make too many stone strokes, you will keep making a new BURR. Note: If you go to the 600 and then the Polish Tape, There will be no BURR"
Well my Cliff my friend...it seems that Mr Dale likes the BURR just fine....Lucky too,being that he based his whole sharepening system on it!
In Other news...
Now what I think might be called "Bur-less" sharpening, is actually talked about on another website that I have been reading where the sharpener actually makes a bur ( oh by the way ALL sharpening systems will form a bur) but you stop stroking the knife into the stone just before the moment the burr flops over to the side and is felt.
Stopping early like this means is that you have made what is called the "wire edge" on your knife.
Now it is very true, the "wire edge" can be "ULTIMATE" in sharpness.
However it's just not able to last very long.
What happens is that a guy will sharpen an edge as normal and yet stop just before the burr is felt.
Then he feels the sharpened edge and thinks he has a monster-sharp edge....way sharper than any other edge he has had!
The problem about doing this that I have been reading about with "Bur-less" wire edge sharpening is that with any use of the blade at all and the unsupported wire edge (thats actually just a very sharp burr that is sticking out straight) will flop over to one side and cause the blade to seem dull again.
(Author, Joe Talmadge has a website about this error at -
http://www.knifecenter.com/knifecenter/sharpen/instruct3.html)
The person useing the wire-edge point will be stunned at how fast his knife went dull.
