- May 3, 2004
The only thing I would add to Page's explanation is about soak times per half inch of thickness; to achieve best results, that should be your minimum soak for any thickness under 1/2". If you make blades thicker then soak longer, but it doesn't work going the other way. As in it says to soak for 20 min per half inch of thickness, so my blade is 1/8" so I soak for 5 min. TOTALLY WRONG. Thats another common misconception.
If you don't believe me, prove me wrong, I have done the tests and so have others. (I was using O-1)
Del
Del
