Stuart Davenport Knives
- Feb 7, 2022
Now knowing the source of your steel, it is quite possible that the issue you're having is the starting microstructure of the steel. Most of their carbon steels come very heavily annealed, which is great for machining, but not so great for heat treat response unless the blade has been forged already. If just doing stock removal, some of their steel requires a much higher than "standard" normalizing heat to break up the coarse carbide structure. A forged blade has already gone through high heats during the forging process. You will get a lot of opinions on different heat treat numbers, and that's fine, but this is what I would do if I KNEW the problem was not decarb, and I KNEW the steel was 80CrV2. I don't think your problem is the canola, warmed to 130°F I have had no issues with 80CrV2 back in the day prior to using Parks 50. 1/8" steel and thinner is what I normally use.
Normalize at a high heat, 1750°F (at least), 10 minute soak, let it air cool (break up the coarse carbide structure)
Thermal cycle twice at 1500°F, 10 minute soak each time, let it air cool (refine the aus grain a little bit)
Austenitize (harden) at 1525°F, 10 minute soak, quench in 130°F canola oil, or ambient/room temp/ Parks 50
I would highly recommend using some sort of antiscale compound like ATP-641 to radically reduce any decarb. But in the mean time make sure that's not the issue by grinding well into thte steel. Sounds like you are doing that, so that's good. 80CrV2 is a pretty forgiving steel for heat treating. But a lot of the carbon steels that come from the Buderus mill in Europe are very heavily spheroidized. It might be the issue.
Good luck!
Good luck!
