Ok we fired up today and I'm more then happy with the results. I still need to add the trigger disconnect bar but that's just a bit of welding. The test run was to 1475° from a cold oven and took under 15min to reach. I then let the temp even out and soak the bricks and then cranked it to 2000°. It hit 2000° in 5min from 1475°
can't complain with thoes results. After 1hr of running through the tests and heat treating some 5160 at 1475° I measured the shell and the hottest I could find was 125-150deg then I shut it off and let it cool to 400° and it took a good 2-3hrs and the entire time I could touch the shell. It was hotter now but not boiling water hot so I say it gets a thumbs up.
Here she is all painted and the control box mounted. Turned out rather good looking I say.
Here is the back side. I went kinda steam punk for the elament power lines and used flexible copper tubing. But it worked really really slick for what I was trying to do.
Here is a shot of inside the oven at 1475°, it's rather mesmerising to look at and even more so at 2000°
I will get some more pictures tomarow as well as a video of it in operation. I was happy with the amount of control I had as well as the controls ability to hold temp. Went first coming up to a set point it would bounce around a tiny bit but never more then +5deg as the bricks warmed up the bouncing would stop and it settled right down. You could hear it adjusting the on and off times as the coil makes a quite humming when on. But so far my strategy for hitting a temp dead on is to just set a set point like 10° lower and set there for a few min then go up to my desired temp and go.
It's tempering right now so we see how it goes. A nice feature is the data logging and real time graph display which allows me to track the temp over time so I can see if something went funky.
Thanks guys for fallowing my along this crazy build and hope it inspired others to eat her relize thy can build one or that it's over there head and thy should just buy one lol.
