.....snip....
It's impossible to take a human element from these tests, so I acknowledge they're not perfect. But I do two side by side and repeatably is generally good, so I take the information I see from this as having value..... snip....
CWF is pathetically/embarrassingly simple compare to this - http://www.cs.virginia.edu/~robins/A_Geometric_Theory_of_Everything.pdf
Luong, may I open my mouth and really show my ignorance? You say, "un-tempered", but I've been reading about "aging" after the quench/cryo. This procedure indicates a low temperature soak, maybe not technically tempering? in the area of 250f (give or take?) for 24-48 hours (or more). But if these steels are being used "as-quenched", then please kindly disregard.
While I also would like to see a side by side comparison of CWF HT vs conventional HT, or even CWF HT vs NC HT, (Nathan's), I do think you're moving in a positive direction. Looking forward to a sort of "mission statement" of exactly what you're trying to achieve along with the technical data. We can learn a lot from those.
This link opens a door.
I would like to do that, but it's not in the cards at the moment.
My standard protocol ....
I don't expect the outcome of this to be a definitive outcome. But, if it compares well to other known good samples, and untempered 3V would generally not be expected to do so, that would tell me his process warrants a closer look.
Will a standard butcher's steel maintain the edge?
...In conclusion: I don't know what a typical full hard blade would have done in these tests, but common sense tells me it probably wouldn't be great because untempered steel is usually too brittle to hold an edge well in rough use...
5: Chopping 16 penny nails. .150" work hardened wire, cut against an aluminum anvil using a 4 pound hammer. All of the knives took significant damage that is visible at an arms length. I ran this test yesterday at 20 DPS and there was much less damage. This shows the significance of a couple degrees in a test like this. Many testers are not controlling this geometric variable close enough to form valid observations.
This is a quick and dirty evaluation of a test knife sent to me by Luong. I dont have the time to do an extremely through comparison, or make the needed full hard control sample, but I can look at a few things here with some accuracy and tighter controls.
In conclusion: I don't know what a typical full hard blade would have done in these tests, but common sense tells me it probably wouldn't be great because untempered steel is usually too brittle to hold an edge well in rough use. I dont know what the application will be for such a high hardness knife, and my testing of this knife was limited and didnt include long term durability testing. But it certainly seems to me that Luong may be onto something here and his work may have a lot of potential in cutlery heat treat. So I can validate some of the claims made, and it is my opinion that this warrants a closer look.
Just how will the normal person sharpen a 65 Rc chef's knife? Will it require professional sharpening? Will a standard butcher's steel maintain the edge?
Luong - we're all REALLY looking forward to details for HT'ing AEB-L steel in Dry Ice.
Ken H>
Thanks for the report Nathan, and thanks to Luong for his efforts and willingness to be open about all of this.
To Marcinek and others - I appreciate your philosophical views as a research scientist myself (PhD Biology and I teach graduate level research design, scientific inference and data analysis). I think it is certainly true that the scientific approach is not a semantic quibble, but there is also a place for exploration and that is what Luong is doing. The formal experimentation and nailing down of explanations will follow if the standard HT paradigm can't hack it (pun intended). Others have already made similar arguments - so let's see where this goes! I'm excited by what Nathan has already accomplished and put into production, and intrigued by what Luong has seen already.
Thanks for posting that graph. It'd be interesting to see another graph showing edge angle graphed against force needed to cut a standard sample.Nathan and Luong both already have a firm grasp of this, but for those wondering, here is a quick chart detailing the difference in edge strength when you sharpen at different angles:
A question for bluntcut:
Since your new HT adds alot to edge stability and toughness will there still be a toughness advantage to carbon steels or mid chromium steels vs stainless steels ?
Will this change the applications of these steels ?
I for one would love a duper tough stainless steel chopper
One of my favorite bluntcut tests is the 66+ Rc blade used immediately after dipping in LN2, a circumstance in which again you'd expect VERY brittle behavior and low impact resistance, but his test suggests otherwise.
