I've seen a lot of people calling Opinels excessively weak and unreliable tools more fit for the kitchen than anything else. They do have many weaknesses, such as low resistance to water and low tourqing strength, but I think their capabilities are greatly understated here in these forums. I'm going to use this thread to post photos of some harder use moments of me and my Opinels.
*The Opinel is a size #10 and the lock is kept disengaged while batoning.
The initial cut. Not a thick branch by any means, but it will work for an example of how things are done.
Some splitting visible.
Opinel batons through a section of wood.
Initial cut finished. These were broken in half then split a few more times, with some one of the pieces being used for shavings.
Dug a small pit, rolled up a dead log and placed the splits above the shavings.
One of the most serene moments I've ever captured on photo.
Still shaves, after having gone through for about 15 fires worth since the last strop or sharpen. Some nice, plain old carbon steel seems to get the job done just fine.
This is by far not the most optimal tool to split open wood for a fire, but it is readily capable. What I did was excessive, in a normal situation I would baton it through for half a foot to ten inches, then use a round piece of wood (Usually the baton itself) to press into the split and finish the work. This is quicker than carving a wedge. This is just to demonstrate that a 12$ Opinel can easily stand up to being hammered through pieces of wood. Hard, soft, dead, alive, knotty or true, I've blazed through it all with no problems so far.
I'm not a fixed blade kind of guy. They have a clear advantadge in many areas, such as strength and reliability, but if I can get by using a large opinel to baton and a SAK Saw to section off wood, then I much prefer that lightweight combo to an axe or fixed blade. I carry small, light loads because I enjoy exploring and I value mobility.
Here are some additional photos from this outing of local wildlife and fungii.
http://i9.tinypic.com/30hrc04.jpg
http://i9.tinypic.com/33z42lf.jpg
http://i9.tinypic.com/47x5c14.jpg
http://i9.tinypic.com/2a91xl3.jpg
http://i10.tinypic.com/2qnxq93.jpg
http://i10.tinypic.com/2hgbij8.jpg
http://i9.tinypic.com/2qmg4fs.jpg
http://i9.tinypic.com/2iuteoh.jpg
http://i9.tinypic.com/2l8ey4o.jpg
http://i9.tinypic.com/2rfsioh.jpg
http://i10.tinypic.com/4ck56gx.jpg
http://i10.tinypic.com/315zf36.jpg
