OK so I bought a Helko Classic 2.5lb axe a couple weeks ago. Opened it up and immediately liked it good balance and the weight I was looking for. Good looking axe. Their was something about the handle I couldn't quite figure out but just new from the rough sanding near the eye something was weird.
I was excited to use it so I chopped up a few pieces of stuff that was laying around. Nothing big and just getting a feel for it. Everything is checking out good but factory edge is dull so I sharpened it up a little. It didn't take much just some lansky puck action.
Decided to scrape the heavy varnish off and wipe it down with some blo.
So I go out back and start to split up some small stuff on the chop block I have.I layed pieces flat and just whacked them. Going right thru them like butter.
Then after two or three it gets stuck in the block and I tug it and it feels like I shifted a gear from first to second and comes out. Didn't register at this point so
I take a break and it comes to me, I stick it in the block again and sure enough the little strip of varnish around the eye pops off revealing a large gap in front and back of the eye.
This is what I sent to them:
"Hi there I recently received my axe and after using it for a few swings the handle has become very loose.
The axe head was not fitted with a properly sized handle. There are large gaps at the bottom of the eye, where the wood should be flush with the metal. I like this axe but I cant use it in this condition. Please advise me what I should do. I am capable of rehandling it if you want to send me the proper handle otherwise I have no choice but to send it back.
See attachments!
I understand that sometimes this can happen for whatever reason. Please let me know as soon as possible so I can have an axe available for an upcoming trip.
Thank You"
Response from them:
"Hello
I am very sorry to hear that you are not fully satisfied with the axe you received. The issue that you described is certainly not typical of our axes, and I will do what I can to make this right for you. Could you please return the axe to us at the following address, and I will process and full refund plus return shipping charges, once it has arrived:
Since this problem could potentially be a manufacturing issue on that particular axe, I will remove that model from available inventory until we are able to further inspect the problem. Again, I apologize for any inconvenience this may have caused, and greatly appreciate your understanding. In addition, I would like to give you 10% off a future order, with coupon code:blahblah blah. Please let me know if you have any questions, or if there is anything else I can do for you.
Best Regards,"
Alright sounds good right. I'm not the kind of person to return stuff But in this case I thought Helko NA would replace repair or refund my purchase.
Let me know if you want to hear the rest of the story.
See attachments!
Thank You"
Response from them:
"Hello
Best Regards,"
