- Jul 20, 2007
Turning it on a mandrel, one side is normally chucked up and the other is supported by a center. Turning between centers requires a lathe dog and 2 centers. One in the chuck and one on the tailstock. One advantage is you can turn the center in the chuck and it will be perfectly aligned. This is as long as it is not removed until the job is complete. Now if you are going to bore the bearing seats then neither of these methods will work. Both require you to have a shaft running through the workpiece. You will need to bore the bearing seats in a chuck. If the machine has a 4 jaw chuck you can dial the work in. By the looks of your lathe it does not look like an adjustable 3 jaw. If you turn the bearing bore then turn the OD between centers this can remove much of the run-out. There are a few ways to go about this. You could almost do the whole wheel in the chuck if you cut the bore then turn the OD without removing from the chuck. The only problem with this is you need a large enough piece of stock to hold and turn without removing it.
I was told that when turning between centres, a lathe dog is not necessary because the work is pinched enough not to slip. It sounds like I need a mandrel anyway to do it.
Our school (I think I forgot to mention that it is at my high school) has a larger 4 jaw chuck that I can put on.
Could I do the rough OD and one side square to it, then cut one of the bearing bores, hold in the inside jaws and dial it in, cut the other seat and the bore going through for the shaft, pinch between centres and do the final OD?
