- Jan 9, 2011
Try close spacing between belt grits around 120 grit or even a redundant stage at that point... 120 ceramic to 100 gator belt (180 grit) or even 120 ceramic to 300 gator belt (120 grit IIRC).
I find most scratches lie within that area and the close spacing between grits really helps. I learned this when I did lapidary for living, I'd go from a 220 hard diamond wheel to a 280 backed wheel and the small jump in grits really removed those scratches I'd see pop up later at around 600 grit... which is another trick... after your last ceramic belt go straight to 600 or so (just a pass or two) and you will really see those deeper scratches "pop up."
Once your base is super clean you can sometimes skip grits, etc...
Also pay attention to your last few passes and do them lightly. You should be able to see the difference between a light pass and a heavy one.
