Well if someone really wants to have a knife fight with me I'm shooting them in the kneecap and running. That said, the sfno or the terror monkey or the tglb.
Tali-Wacker
... this followed by the TGLB. The SARGE/SAR handle is going to get slick with blood and I would wager see your grip sliding up onto the blade when plunges in. I have seen plenty of hand injuries from people who "slid up the blade" cause the grip was slick. I prefer the DSF to the SAR handle in this regard as well. The Tali looks and feels like it was designed to fight. It probably has just enough forward weight that a good downward chop will be damaging across flesh.
I think by definition a fighter must be light and fast in hand, which eliminates almost everything mentioned here so far. Busse's are not fighters, no matter what the designation (typically). They are combat knives which place a high priority on utility and durability, with everything else being secondary like cutting ability and fighting characteristics.
For a fighting knife I believe it must spec out to no more than 1 oz. of weight per inch of OAL in a blade, with less weight per inch being even more desirable. Anything over 1 oz. per inch makes for essentially a utility biased knife, which is often the form a Busse takes and 1.5 oz. per inch is not uncommon. Take the NMSFNO for example, weighs 21 oz. with 14" OAL. That's not to say you couldn't use this knife for defensive purposes, it would just be far from ideal as it will not be very nimble.
Choils are also a serious handicap on a fighting knife and a prominent feature on nearly every Busse and kin to date. This is an undesirable feature on a fighting knife, due to the greatly increased propensity for snagging on clothing, bone, etc.
That being said, the choilless Boss Jack LE is probably the closest I am aware of to a 6-8" Busse that is reasonably well suited to fighting.
What he said. A fighting knife is a 10 - 12" bowie, with a distal taper and a sharpened clip. See Bill Bagwell:
https://s3.amazonaws.com/cdn.paladi...And-The-Best-Of-Battle-Blades-Free-Sample.pdf
