- Oct 19, 2011
Hi Constantin,
Thank you. I have worked in A2 and 01 but I don't specialize in them. I have had good results with my equipment but maybe folks that do hundreds or thousands of knives in those steels can chime in and give some heat treatment routines that are proven for them. You can also do a search to find a number of things that will work. Then you can tweak for the best results with your equipment. Heat treat routines can change over time as you renew batches of steel or upgrade your equipment but to answer your question these are what has worked for me and my set up*:
01
Normalized @ 1650˚f, 1450˚f and 1250˚f
Pre-heat @1250˚f for 10 minutes
Austenitized @ 1500˚f with a 20 minute soak
Quench in ambient Parks #50 oil
Tempered @ 400˚f for 2 hours 3X
A2
Wrap blade in stainless steel foil packet
Pre-heat @1250˚f not exceeding 400˚ per hour, equalize for 15 minutes
Ramp up to 1400˚f not exceeding 400˚ per hour, soak for 15 minutes
Ramp up to 1750˚f not exceeding 400˚ per hour, soak for 45 minutes
Plate quench for 1 minute then water cool
Place blade in sub zero bath (alcohol/dry ice slurry) for 30 minutes
Tempered @ 400˚f for 2 hours 2X
* My set up (the basic stuff):
Wuertz TW-90 Grinder
Evenheat KH418 with Rampmaster controller
Parks 50 oil
Plate quench press with 1.5" thick aluminum plates
01
A2
Parks 50 oil
