Can't add much to the good advice given above by Ripcord 82. I like the "Green Brick of Joy" quite a lot. The actual feel or "feedback" of the stone is quite pleasurable. Creamy smooth, and reminds me of my King 4000 and Suehiro 8000. Mine came with a little instruction paper that shows you how to keep the stone "happy"! It's a silicon carbide stone, but heavy on the binder and light on the SiC, which gives it the creamy soft feedback.
I only use edge trailing strokes on it, and hardly raise any mud. With edge leading, I never cared for the apex it made, but edge trailing changed all of that. As far as soaking, the instructions on how to keep it "happy" mention what to do. I forgot honestly, but IIRC the instructions say that it should be used as splash and go, it "can" be soaked for 5-10 minutes, but "not" to perma-soak it. I always soak the thing for 5-10 minutes, seems to work a little better and not load quite as easily. As far as pressure goes, edge trailing, I use a just a little bit of pressure (maybe a couple pounds??) at first, and then lighten up on the pressure towards the end.
Some people don't like the stone, and I can see why if your technique is off, mainly edge leading with pressure and mud. Doing this is GREAT for burr removal, but leaves a rounded apex. I always remove the burr on the coarsest stone I plan on using, and then alternate sides left-to-right / left-to-right on all stones after burr removal. Edge leading on the GB was giving me less than satisfactory results. Edge trailing and ever lightening pressure transformed my opinion of it. And there is a LOT of stone for the $$$, too.
With all that said, and just as a personal preference, 2k (8 micron) is even more refined than I like for meat/protein cutting. Usually I stop at 25 micron (DMT Fine), or a bit further at 16 micron (Shapton 1k). You might, if not already, try using your King 1000 (or 1200) as your finish/maintenance stone. They're soft, so like the GB, I recommend edge trailing and light pressure. Have the edge geometry and burr removal already done on a coarser stone, and finish/maintain on the 1k. Compare that edge retention with the 2k, and see if you really need a 2k stone. YMMV!
