evilgreg
Why so serious?
- Dec 25, 2012
So much confusion.
Agree to disagree, I guess. In my experience, my thick bladed folders cut poorly in many cases, even if they're only thick at the spine. If you make any sort of deep cut, a thick blade produces reduced cutting performance.
Or maybe I'm just imagining that my scrawny, thin-bladed William Henry E10 out-cuts my brawny ZT knives (or even the hollow ground and reprofiled to a reasonable steep edge Southard that I usually carry). For actually cutting stuff, I've always found thin > thick, unless you're chopping or prying or whatnot--and I don't often see a need to pry or chop with a folder.
Most folders have blades that are IMO way thicker than they need to be, presumably because that's what folks want to buy. It's outright silly to suggest that a thick bladed knife like the ZT 0801 or Spyderco Southard can cut as well as a blade half the thickness, like a William Henry E10 (I'm just using these three as an example because they're knives I've been carrying of late). I carry the Southard and 0801 because they're fun, but outright cutting performance I'd have to admit the dainty little E10 actually cuts better.
Spine thickness effects lateral strength of the blade but has little effect on cutting efficiency without respect to blade-height.
Uh, okay, assuming the only type of cutting is surface slicing.
Edge thickness effects cutting efficiency and also edge-durability. A blade 1/4" thick at the spine can be just as fragile as a 1/16" blade at the edge, making it unsuitable for chopping into hard objects despite superiority in lateral strength. Similarly, a 1/4" blade can cut with the same efficiency as a 1/16" blade if they sport the same thickness behind the edge, depending on the cutting resistance of the material and the depth of the cut.
For benchmarks, use a standard box-cutter blade for thickness. If you need more lateral strength (i.e. prying), move up in spine thickness but grind as needed to keep edge-thickness the same. If you are not sure where to measure edge-thickness, it should either be where the primary bevel meets the secondary (edge) bevel (the shoulder) OR just measure 1/16" back from the apex (a common edge-bevel width).
Good general use cutting geometry = <1/16" wide edge bevel, <0.020" thick (<15-dps), followed by <5-dps primary bevel to the spine of whatever thickness. My $0.02
My $0.02: you can sharpen the crap out of a prybar like my ZT 0801 and it will never glide through a cardboard box like a box cutter, even if you could make it comparatively thinner and sharper at the edge, because the fat blade would still wedge and drag. Take a 1mm thick blade and a blade that is 4mm thick at the spine but ground just as thin at the edge as the 1mm thick blade, then slice up some vegetables using both and try to tell me that the thin blade doesn't cut better . . .
