TENTEX
- Sep 2, 2017
Does the Meaner Street fit the Radioactive Duty sheaths in your experience?
David might be able to chime in. But my RAD fits but it a bit tight
Nope completely different blade.Does the Meaner Street fit the Radioactive Duty sheaths in your experience?
Man the old meaner was so much more mean than the new meaner.
Close but no cigar.HUH???
They seem quite close to me in most every way...
Funny you mention leather.close only counts in...............................horseshoes and Hand Grenades![]()
so close-ish ? in a loose leather sheath maybe
Drop point (Mountain Active Duty) vs straight Back (Meaner Mountain Street
Close but no cigar.
And yet you'd be lucky to even find one of the originals at this point. What specific features or differences are you noting that seem to lacking in your opinion?
Dave, while I respect your opinion and would agree that would GENERALLY be the case in most instances.... it is not entirely factual in my direct experience in recent months/years.
The Scrap Yard WS-1020 seems to be the starting point or 'blank', if you will, for many of the other WS-XXX series when they were designed. It's pretty much a straight spine with a heavy and deep belly so you can ultimately make any other blade shape from it that you like, even a wharncliffe. The same appears to be true of the DB-321 being a starting point for the rest of the large Res-c SYKCO blades currently, you can literally fit each knife they've released in that footprint.
I know for a fact that the WS-621, WS-221 & WS-1121 that I currently have or have owned will all fit into the WS-1020 kydex I have from Mashed Cat. Using your logic none of them should fit at all because...... different blade shapes... right?
Now, do they fit well enough that I'd recommend using them this way? Not entirely, unfortunately, yet the WS-221 has literally zero play or slop. I have actually carried this knife in this way as it's got the same spine height far enough down the blade to fit perfectly.
In fact, for this knife carried IWB with either Discreet Carry Concepts Clip or IWB Biothane Rubber PTD loop I find that configuration ideal as it gives more height to the sheath below the belt to stabilize and prevent the knife rolling out from the belt line. I would actually order that WS-1020 sheath for the WS-221 rather than getting an ideally sized WS-221 like you and others sell for this reason, that is, UNLESS I wanted to pocket carry where the extra length can. be a hindrance.
This is actually a common practice among many holster smith's out there producing Appendix Inside The Waistband holsters and the like because it's very noticeable difference to many people, as you have a lot of weight above the belt in the pistol's frame or grip and very little below the belt to counterbalance. So adding a longer length to the holster despite being technically unnecessary can increase both comfort and concealment.
I say all this to mean that it's very difficult to give blanket statements and NOT end up being completely off base in some instances. If you do not have DIRECT experience with the actual knife and sheath in question it would generally be a good practice to not speculate on these things. I asked TENTEX because I knew had actually had the knives in question along wtth one of your RAD sheaths because I'd seen them here before.
My mistake to have made an educated guess based on the past models of Meaner Street and Active Duty (which I still own and have in my possession) on this exact blade before my actual knife gets here .
I will wait until my Mountain Meaner Streets gets here to make any further comments on this subject relating to this exact blade.
Have a great Sunday, I know I will![]()
Just look at a picture of both. I personally think the original is cooler. This new one just didn’t appeal to me.And yet you'd be lucky to even find one of the originals at this point. What specific features or differences are you noting that seem to lacking in your opinion?
