BluntCut MetalWorks
- Apr 28, 2012
I am pleased with the result because from data, this knife edge is very stable at current geometry & hardness. It's a very thin kitchen knife for slicing soft food materials but it capable to withstand cardboard + rope + somewood (as long as no gross lateral/twist) but can't chop bone. I agree with lowering the hardness to 63-64rc if the knife has more belly & less or no flat section designed for non-pinchgrip and chop cutting style. And probably increase behind thickness to 0.01" and 12.5+dps edge bevel.
Edge retention for this class of knives should be quite high just from sheer compressive strength. W2/52100/1095/0.9+%C steels with good ht should yield straight razor sharp and high durability edge (fine grain & tiny carbide). This knife can be fun for sharpeningKnuts to see how sharp it can get and what edge geometry would support various type of bone chopping. As long as operation doesn't exceed the edge+apex yield strength. Also mean it might be necessary to increase apex width to eliminate micro-deformation/chip.
My 2nd 24.5cm W2 gyuto handle epoxy being cure. I expect this 65rc has better toughness than knife #1. It's 65rc probably from toaster oven overshoot temperature during straightening process.
Jim Ankerson - I will grind off the chips and give this knife a kitchen life. When time permits, I will make & test super quench W2+52100+1095+blue#2+white#2 kitchen petties with hardness 64+rc.
Thanks for sharing bluntcut.
So the conclusion is then either drop down the rc to 60-61 and/or change the apex angle with a bit more substance behind the edge. The advantage of a thin kitchen knife is obvious so maybe the first?
Plus, don't forget, we all love sharpening so a knife that never gets dull or cuts like laser even if dull is a "nightmare" ��
