- Mar 1, 2010
Which pocket? Also was it tip up or tip down?
Left pocket. Tip up.
Aha! so tip up can also be unsafe...
When carried in the wrong pocket yes.
So it'a the pocket that's safe. Not the knife.![]()
Conjecture!!!
Even with a weak detent, if carried it in the right front pocket there wouldn't be anywhere for the blade to go because it would rest at the seam.
Now that doesn't always hold 100% true.
I had an Emerson which the blade could be shaken out. I wore it a couple of times in the right front pocket of athletic shorts (very thin and light material) when I went running and it would open up a little bit because of it swinging in my pocket. A little annoying and a bit unsafe. To combat this I did two different things. When carrying the Emerson while running I would put it in my waistband right on my right side. That way it didn't swing and wouldn't open. Or I would carry a knife with a stronger detent that wouldn't open. Even with those knives I found it more comfortable in the waistband so that's where they go now when I run.
Also never had a problem when moving or running with pants that are a sturdier material. Athletic shorts have a lot of give.
If that happened to me with my Hinderer I think I'd be dead: https://www.youtube.com/watch?v=7fIbnvAsD-k
... I notice that I can actually shake the blade out just by shaking the knife. Am I wrong in thinking that this is a safety concern?
You are not wrong. It is defective knife. The detent ball is to hold the knife in. It should not open by shaking on any liner or frame lock. It should be this way from the maker, you should not have to modify it at all. Don't listen to fanboys who tell you it is OK, believe your gut. If you tighten the pivot to "fix" it, you are not really fixing anything, just using the pivot to hold the knife closed...like they did before Walker invented the ball detent.
Send the knife back before you do anything to invalidate a refund or repair. If Hinderer or the dealer tell you it is normal, get a refund.
OTOH, what you're saying is a fallacy. Post hoc, ergo propter hoc.
I don't believe it's a fallacy, just my experience and opinions with tip up knives. YMMV
Based on what a lot of other posters has said about Hinderers I'm sure the weak detent is to blame. It's my opinion that if it was carried where it was designed to be it would be less likely to happen.
To be fair, the OP only said "Left pocket, tip up" so there's conjecture on my part by assuming that its left front pocket as opposed to back.
Yes, I did have to Google the Latin.![]()
I am not a hinderer fanboy. I dont own any, never have and probably wont unless its a collab. While i agree that i wouldnt want a knife like that there are some who like them that way. If rick sets his knives up that way they are not defective. He simply doesnt build his knives to our liking.
It is not a matter of "taste" but design function. There's a lot of makers, including the designer of the modern liner lock, who believe a ball detent should hold the knife closed until the owner want it open. A knife with a liner lock that opens w/o intent is a sufficient & legitimate reason for return.
It is a matter of taste as all makers do things a little differently. Even if there is an overall consensus of what should be if you intentionally do not then is that way on purpose. ZT likes super hard detents. But that doesnt make a hinderer or CRK defective because their detents arent as heavy. And despite what "a lot of makers" do those makers are not Rick Hinderer. Im sorry many but too many people take the way they like something done and hold that up as a the standard in which all others should be measured. That is fine, you like what you like and it is the popular opinion. But others can do it a different way on purpose. Even if every single maker besides rick came on the forum and stated that a detent should be strong enough to not be able to shake the blade from the handle it would only apply to them. If a maker says "yeah I know what the norm is but I make mine different" then there is no argument. There is not a case for an item being "defective" if the item works in accordance with the makers intentions.
