- Sep 29, 2015
Willie,
That might be it. Next time I get to work on them I'll grind them a bit more and see if that helps. Maybe I didn't grind them enough after the HT. I worked from 80grit to 400 on the belt sander , then hand sanded to 2,000. I didn't expect it would be decarb because I assumed I ground off enough material. But I did rush a little the day that I ground them post HT. And hand sanding doesn't remove
Definelty something I didn't even think of. Better to give that a try before completely re HTing the blades.
