- Jan 1, 2006
Kifaru Zulu, never should have let that one go.
Eagle MOLLE Becker patrol pack, same
Eagle AIII/TAG chaos
Mystery Ranch (MR). Hands down in my opinion. I have a black Three Day Assault (2000 CI) pack with a laptop carrier stitched in (by Mystery Ranch... AND it can be removed with two zippers) for around town/carry on. It doesn't look too military.
I have a MR Dragon Slayer (2200 CI) in Multi-Cam for day trips and light overnighters.
MR Big Horn (2900 CI) for heavier day trips and weekends out.
The above three packs all use their tri-zip design which allows easy access to ALL of the packs contents.
MR Longhorn (2900 CI; discontinued) for a dedicated SAR pack (Top loader with a "waterproof" bag type horns that you buckle together over the top.
MR BDSB in Foliage (Big D's Special Blend; similar to current Kodiak @7400 CI) for HEAVY trips. Never been used yet LOL.
The owner, Dana Gleason is the genius behind Dana Designs packs from back in the day. He has an phenomenal understanding of how the body carries a load. Packs are stitched up in Bozeman, Montana still and they make packs that carry AMAZINGLY well. They use 500D Cordura mostly because it is lighter, will absorb/carry less water when wet and offers significantly better hold at the seams because there are more fibers for the stitching to hold which is usually where packs are going to fail. They acknowledge that 1000 Cordura is superior in abrasion resistance and use it in limited applications. How many times have you worn through pack cloth?
I love Kifaru packs too. I have owned 5 Kifaru packs and sold them all so I could get one more Mystery Ranch pack. You won't ever be able to pry my Woobie out of my hands however!
Semper Paratus Tactical's 3-day/Assault pack.
1000d cordura, configurable compression panel(s), plenty of MOLLE for adding accessory pouches (also available), sculpted shoulder straps, padded outer pockets, hydration sleeve with dual ports, "drag handle" and built like a tank by one of our own... Everything you need and nothing you don't with room to add those "extras" you discover you needed but didn't have "the first time".
I've had mine for over 7 years, have taken it everywhere (including multiple trips to blade as a "steel/INFI/Kydex" hauler) and it still doesn't show appreciable wear. I know Randucci (not CloneDucci, Fakeducci, the REALDucci mind you) has one as well.
Right on, I have had mine about as long, I know Brian has had his longer, but it seems like I have had it forever. It has been to Australia, France, Italy, Spain and Blade every year. It is always my carry on and seems to fit everything I need plus some. Like Brian said, even though it has been around the world, it shows no wear, no fading, no fraying, nothing has broke, probably will never need another pack.![]()
Just checked his (Semper Paratus) site. Too bad he doesn't have anything but sheathes listed anymore.
