Hollow Tube Fasteners
Doug, the "off sets" are .25" outer diameter threaded tubes. I bought them .25" long to fit exactly within the tang of the knife. The screws are 5/16" long and thread into the off set about 1/8" each, therefore filling the 1/4" long tube when you consider both sides.
I think if this were going to be my long-term set-up, I would epoxy the off sets into the tang holes to keep them from shifting or spinning. But since I haven't made up my mind, I just turned the screws from both sides at the same time (with a little loctite) to cinch the scales down.
It feels pretty secure as is --- for "air swings" anyway...
Sounds good. Keep us posted when you get the new handle materials.
I look forward to seeing it.
It sounds like you have likely decided to forgo the flared tubing - ????
But, screws vs. solid pins sounds like the current decision for you and I would guess it is largely based on whether you want to have the option to change scales or do it permenant (????).
Doug,
I actually bought some stainless and brass tubing as well ---- just trying to decide what would look best and what I could do w/o screwing it up! LOL
Did you get any more info on which type of tubing is strongest and/or best for heavy duty handle retention?
Which is best for flaring without splitting?
Any more tips and tricks about flaring without splitting?
Etc.
If using the factory scales, I think flared tubing would obviously be fine, but not as easy to change out if changing scales. I tend to think you are more likely going to stick with one set of scales if you figure out which ones you like most. I don't think most people would be interested in having "interchangeable" scales. - Just whichever ones you like best.
Because of the counter-sink in the factory scales, you are likely to be better off with flared tubing or a screw-set up that has a washer you like. Personally, I don't mind the look of the screw heads on the factory scales. They look good to me. But, I doubt the screw heads or flared tubing would look very good with custom wood scales. With custom wood scales, (personally) I would likely go with the fasteners you can grind the tips off after install to make look like solid pins. I would personally probably use some epoxy as well. I think a lot of knife guys use Devcon 5 minute epoxy or Devcon 2-Ton epoxy. From Devcon's website, it appears the 2-ton is a little stronger, but I am not technically sure which would be best for a knife (????).
attachment.php
Devcon 2-Ton - Technical Data Sheet: http://www.devcon.com/techinfo/179.pdf
Devcon 5-minute - Technical Data Sheet: http://www.devcon.com/techinfo/175.pdf
I think you can get Devcon at Walmart, Home Depot, Lowes and similar (???).
In the pictures, the screw head and washer combo looks pretty good. But, you mentioned calling for larger screw heads. I couldn't help wondering if there might be an option for some type of specialty counter-sunk / tapered / decorative washer that would accomodate the screw head (????). Maybe a local machine shop could fabricate something out of stainless (????)
tubes crack because they do not have flat ends. it is important to use a lathe to cut your tubes and have flat square ends. using a hacksaw or pipe cutter won't work most of the time.
tubes need to be .250 x .028-.030 wall thickness. :thumbup:
Thanks Skunk, that may have just saved me some expensive blocks of wood...
