- Jul 11, 2020
Thanks james im a little stumped myself LOLC CTrelichunter thanks for sending me this pic via email:
I'm far from a pro in hydraulics... I think they are the same valve. Which is odd since I don't have this issue.
There's your answer right there, the "ESA1" is an Open neutral which allows the cylinder to move with control n the center position. Looks like you need the "EDA1" which I "understand" (understand, not "Know for sure) is Closed in the neutral position.
Per the drawing on the first page of this thread, that control can be chance from open to closed by adding the 3/8" NPT plug as shown in the drawing. Looks like you're in luck. i know nothing with these setups? not even sure what to do but thanks
so im guessing i have to remove hose on out port and put a plug in there? thats it? i know nothing about hydraulics reallyIf you try using the plug let us know how it works. Glad you started this thread - I've learned something.
mine would be the M4-ESA1 James thanks for all your help appreciate that i will put a plug in tomorrow and try
ken your the man appreciate all your help ill put a plug in tomorrow i ordered 1 earlier on amazon will post my findings as soon as i can thanks to everyone who has been trying to help me you guys are awesomeI'm not totally sure which is the correct part number. See my edited post in thread #24 above for more discussion. Looks like I'm showing everybody just how much I'm NOT a hydraulic expert.
10-4, I know that's the one you ordered. I'm trying to figure out which one wouldn't have had the issue.mine would be the M4-ESA1 James thanks for all your help appreciate that i will put a plug in tomorrow and try
my Bad10-4, I know that's the one you ordered. I'm trying to figure out which one wouldn't have had the issue.![]()
yes actually i do thats what i ended up using thanksDo you have a post vise you could use that. If you can build a press I made a simple twisting jig with square tube welded on the ends. On a safety note I would cover the hoses.
