Mark Williams
Moderator
- Nov 28, 2000
A thousand years from now its going to puzzle the hell outta the folks that dig up all these pieces of perfectly good wood with a piece of crusty rust in between.
Rovert said:remember there's a fan in the microwave that ventilates the chamber, so I don't understand where the notion of vapor concentrations enough to explode the thing are coming from.
Disclaimer: What I do want to say is that you need to do this at your own risk. I'm not a lawyer, nor do I play one on TV, but common sense prevails. Don't blame me if you blow yourself up.![]()
Walt2 said:The steps that paintfool described using a jar in a pot is exactly the procedure used when canning pickles in jars. You don't have to pour the hot water in the pot, you can do it on a stove or one of these fish/turkey frying setups. Just don't heat too fast and when you remove the jar from the hot water, don't sit it on anything cold. Once removed from the hot water, tighten the lid down good and when it cools, it will form a vaccum.
Dan, look at the bright side of it. I've either stumbled on a very competent and effective home stabilizing method, or I'll have the first AC powered home-made thermo-nuclear missile.Rovert take a lighter to the fan while it's working maybe you'll prove me wrong, I hope so but I want to use your disclaimer
Uh.... wanna say that again... in ENGLISH????These Loctite methacrylates and other polymers are very expensive, and thus the highest part of the stabilizing cost. After impregnation they are often spritzed with a peroxide initiator to catalyze polymerization to a solid.
Hey... yeah, but he always came back in the next cartoon, right???You remember the coyote?
good IdeaDan Gray said:a vacuum then into a pressure cooker would work very nice.
