Rovert, if you meant me, then my answer would be "No, I don't know of any pure polymers available at local places like Lowes or Home Depot." That doesn't mean there aren't any, just none I know of.
The methylmethacrylate ploymers and such are only available through places like science supply houses or places that distribute Loctite products or places such as
www.polysciences.com .
I've decided to do some experiments with uptake of material and post-treatment wetability here at home. Dimensional stability, the other important factor, would be hard to measure since the changes that would aggravate us are very small to discern in a block that's not on a knife. Still, I'll put a caliper to them to see if I notice anything. I have a vacuum pump, pressure tank, and scale to measure weights. I plan on doing some work with Nelsonite, Minwax, solvent-based polyurethane, and others I can think of. I've already tried water-borne polyurethane and it didn't work for me (poor penetration and quickly thickens under vacuum). It will take awhile but I will post data as they are available.
I've contacted a friend who has had success with MMA but it is a laborious procedure because an inhibitor had to be removed prior to use, otherwise it won't harden. If there isn't any stabilizer, it won't have squat for a shelf life. I'd like to investigate this Resinol90C but can't afford $300 for an experiment.
Something else that occurred to me is that perhaps it's best to let these dry in air for awhile after "soaking" and before any vacuum drying in order to prevent the liquid from being sucked right back out of the pores before it dries.
I'm beginning to think that despite the fact I really like home experimentation because of my background in science, that perhaps it would be cheaper in the long run just to send the danged wood out to the pros if one wants complete "plastic" stabilization. We'll see.
