Ive been meaning to pick up a radius to fit a bader/esteem style tool arm or adapt one. Never have gotten around too looking.72 inch Nathan platen, baby!!!![]()
Ill probably end up making one myself
keep in mind there are "bend sticks" for straighting the soft spined single bevels
A way to get Urasuki without a radiused platen is to hold your blade at an angle to a large contact wheel (10" to 16") and draw the blade across that grinder along the heel to tip axis. It only takes a little angle to greatly increase the width of the hollow. Try it on a scrap piece of 2" bar to get the feel of it.
I would like to have a 120 or maybe even a 144 for the bottom curve and facets on “dropped wa” kitchen knife handles, the spine of curved blades, etc. I use my 36 and 72 for about everything other than hollow grinding blades.befor i got nates platen i mocked one up out of wood. lasted for the knife and let me know i liked that radius hollow
Joe!, Not sure if its too pointy? But your Vehicle is dirtier than mine!I did a rough profile of the forged blade shaped object. It will probably go back under the hammer for some final tuneup. it ended up being like 275mm from heel to tip and about 33mm tall with spine and edge ground to clean, straight steel. It is still quite thick, almost 6mm at the spine most of the way out the blade and not much in the way of big dents, so I have material to play with. Is it too pointy?
Really, I don't forge, but I like to start out with way pointy in my first profile because grinding will always round it out some!
