I use a mix of that (or a very similar) color chart and the magnet. I bring the metal up to temp and as I get close I'm keeping an eye on the colors (it's never 100% consistent as it comes up for me) and use the magnet to check. Once an area goes non magnetic I have a reference point that I can match a temp to color in current conditions and I go from there. I'm not so much saying "I want this color off the chart" as I am using the chart as a sliding scale that I peg to the magnet test as I go in order to match the actual situation.
This is not to say I wouldn't LOVE to use a fully temp controlled or at least monitored forge with regularly calibrated instrumentation, but I took the advice given here and use a fairly forgiving steel with a simple HT that lets my relatively coarse temp control give reliable results.
Oh, and as a fellow RIT geek I have to agree, trying to work straight off a color chart is no more reliable than the calibration used start to finish in creating, displaying, printing and viewing that color chart and matching it to the viewing conditions during the comparison. Even with high end equipment and a lot of care you can get two very different looking charts from the same source.
Here's one that'll mess with your mind. Imagine we had Pantone color calibration for this. If you somehow had one inside the forge you'd have to have it adjusted for the color temp inside your particular forge AND the light being given off by the blade once heated. If you use it outside the forge you'd still have to deal with light mixing from whatever light sources are around plus the changing color temp being given off by the blade. A white sheet of paper is not going to show as white when placed next to a glowing hot blade, even before factoring in the actual heat turning the paper into a fire hazard.
I only touched on the science of this stuff at school as it applied to my work, more a "how do I" rather than "why", when I needed more I tracked down folks like Page and let them explain it to me or just figure it out and tell me what I needed to change.
On a more humorous note. I'm going to see if I can dig up a pic of a friend of mine that shows just how deceptive light can be to the human eye. You guys will like it, sexy red head in a short dress....
If you want a larger file - http://www.wolfweb.us/images/sarahwhip.jpg
This had a white background with two different gels over the lights being used to light the background with some spill over onto her. In person the eye compensated so much you really couldn't see the colors on the background, they were very faint. On film....
yes, and by saying that you are implying a person can't make a knife without that "color chart"
you were told how, you questioned it's validity- and were promptly told the shortcomings because of variables affecting the color chart, along with how he knew his oven was accurate.
you obviously are taking it a bit too personal
if your machine hasn't been "Laboratory" tested and calibrated each year, there is no way to tell if it is right or wrong, if it is high or low.
I ask this question sir, How do you know....?
"I" have been an engineer since 1985 and know a little about technologies, electronic and other wise..
not trying to pic a fight or anything, "just say'n"
virgilio palmer
I thought you were supposed to use taste to get the most accurate temperature readings?
Here is how I check my pid thermocouple so I know its right
I cut a small piece off a 99.99 pure siver coin I have for this purpose. I set the piece in 3 sided ss foil enclosure with the open end towards the door of oven and the silver and end of the thermocouple inside shielded from the elements by the ss foil walls. Then I start at 1745 and go up 10f at a time waiting 10 minutes at temp and see where the piece of silver slumps. It should melt at 1761f. So if it doesn't melt at 1755f and is slumped at 1765 I know I am very close. Closer than any color chart anyway.
virgilio palmer
