- Apr 14, 2011
Hey, all.
I know that 1084 with a quench in canola is the generally prescribed HT recipe for newbies/those w/o HT oven.
I'm curious to find out about how close to the full hardness one can get straight from a canola quench, assuming the steel was at the proper austenitizing temperature, canola was heated to 130, proper agitation -- essentially, if the HT were as perfect as is could be from a primitive setup, how close to the full hardness of 65 (HT'ers guide states 65 is full hard, although their formulation doesn't have the manganese Aldo's does) would one be able to get vs. using a HT oven and say Parks or other formulated quench oil? A point or two off, or a larger gap than that? Or is the hardness roughly the same but the structure is a larger percentage Ms/lower RA likely with proper quench oil because of the faster cooling rate?
Also, using Aldo's 1084, does anyone have an approximate table of tempering temps and corresponding HRC values? I've seen several -- some with 1080, some 1084, and even just the ones pertaining to 1084 varied quite a bit.
Naturally a Rockwell tester would be ideal, but I can't seem to find any machine shops or commercial heat treaters in the area who have one.
Thanks!
Thanks!
