- Dec 6, 2020
Pick up a new strop and some diamond or CBN paste/spray/emulsion. If you're doing one strop, I'd recommend 3 micron.
Anybody care to recommend a good diamond paste/spray/emulsion? Thanks.
I've tried a few, and the ones I like best are the CBN emulsions from KME, but they're pricey.Anybody care to recommend a good diamond paste/spray/emulsion? Thanks.
There are other good brands, but I have Jende emulsion. I would highly recommend.Anybody care to recommend a good diamond paste/spray/emulsion? Thanks.
Yep, same guy, but I just noticed that he's sold out of the diamond spray, and Portland Knife House doesn't seem to have an online shop.
This is from one of the members here. Northwest_Knife_Guy. I have both types of spray and love it. https://www.bladeforums.com/threads/diamond-spray.1777993/ He sells super quality strops too.
The KME Emulsion's that were mentioned by another poster were made by Ken Schwartz and Ken has since passed away.Anybody care to recommend a good diamond paste/spray/emulsion? Thanks.
What is it about Gunny Juice that you don't like.Man, I've seen a lot of good feedback for Gunny Juice, but I'm not feeling it. I've got the 3 and .5 micron and find it just okay.
It's not that I dislike Gunny Juice--it's just that I find it *okay* and not meeting the hype. I've used it on everything from Henckels stainless to Maxamet, and many in between. I've used it for mirror edges as well as for edge touch ups. The only apples-to-apples comparison I can do is the Gunny .5 vs the KME/Schwartz .5. Between the two it isn't close. The KME emulsion cuts faster and leaves a brighter polish. I bought the KME emulsion maybe six months ago, so perhaps more recent batches have been inferior. I did recently buy a bottle of the KME .1 micron and, tbh, I don't see much difference between it and the .5.What is it about Gunny Juice that you don't like.
I know found me the last 2 times I got emulsion from Ken Schwartz it sucked really bad and didn't seem like it was cutting at all,I know a lot of other people reached out to me on facebook and asked me if I was having problems with it and told me they were as well.
What are you using Gunny Juice on and what are you going for mirror polish or just a deburred edge.
I found the way that Gunny Juice takes a bit to absorb into wood or leather effect's how much diamond goes on the first time because you need to put in on a lighter coat the first time.It's not that I dislike Gunny Juice--it's just that I find it *okay* and not meeting the hype. I've used it on everything from Henckels stainless to Maxamet, and many in between. I've used it for mirror edges as well as for edge touch ups. The only apples-to-apples comparison I can do is the Gunny .5 vs the KME/Schwartz .5. Between the two it isn't close. The KME emulsion cuts faster and leaves a brighter polish. I bought the KME emulsion maybe six months ago, so perhaps more recent batches have been inferior. I did recently buy a bottle of the KME .1 micron and, tbh, I don't see much difference between it and the .5.
You do what works for you, but using heavy pressure on diamond plates is believed to shear the diamonds and cause excessive wear. Eventually you will end up needing to replace your DMT prematurely. The general consensus from a lot of people who have experience in this area is to use light to moderate pressure only and let the diamonds do the work without overly damaging the working surface.I carry a Hinderer every day, usually in M390 and occasionally in 20CV. Both take hair popping edges. The first step is setting a bevel on a DMT Coarse, which is 325 grit. Use some real pressure and a only two to four passes are needed to reset a nice bevel. I really lean into it.
He was talking about DMT not Arkansas.Arkansas stones are not diamond, that’s why he can lean into it.
They are a softer stone which is why he said they aren’t supposed to work on those steels. But as he said, using that method is getting good results so I m not gonna argue with results.
I use Diamond Matrix stones and yes, a light touch works much better.
Why are you doing that , what's the point to do that way ? Are you in a hurry somewhere ? Why not eight passes and let the diamond to do the job ?The first step is setting a bevel on a DMT Coarse, which is 325 grit. Use some real pressure and a only two to four passes are needed to reset a nice bevel. I really lean into it.
