kuraki
Fimbulvetr Knifeworks
- Jun 17, 2016
There are a few different ways. The quickest and easiest way is to use a parallel, you can make one from G10 or whatever blade stock, doesn't matter as long as it's flat and parallel. Say it's .100 thick as that will work for most anything. Put it on your press table and with the spindle off, run your counter bore bit down until it's touching your parallel with the cutting edge. Set your stop at that point. Check it again and take note how much pressure you put in the quill, and use the same pressure when counter boring. Now when your scale is on the table the cbore will stop .100" from going through.
