These threads have popped up time and again lately.
The running consensus seems to be (from my pov)...
Best- Bandsaw. Harbor Freight portaband (actually on sale right now) is recommended probably more than anything else, but will need to be mounted some way, whether that be using an expensive table or just clamping it in a vise.
Better- High tension hack. These are the ones that have a lever under the handle for applying added tension. Used with good bi-metal blades they work well, if slow.
Controversial- Angle grinder with steel cutting disk. One side says they are just too dangerous. The other says that with proper ppe, leaving the guard on and common sense makes for a usable solution.
After that you have the plasma cutters, water jet and laser cutter services.
I'm using the hack. I have an AG that I bought just for this purpose, but I don't have a leather apron yet. I didn't plan on getting a bandsaw, but seeing them at HF yesterday for $80 (plus throwing on the coupon) it made it look very attractive. Not just that. As with a lot of things in my shop, if I had just bought the best tool (bandsaw) from the get go I wouldn't have been in it for much more than I've already spent on the hack, blades, AG and disks.
