Joe asked:
"...are you impressions based on controlled tests, or just a loose comparison with your other knives? Note that with that last question, I'm not trying to discourage anyone from posting -- if your opinion is based just on a loose comparison, I still would like to hear it, I just want to be able to separate impressions based on more-controlled tests vs. those based on looser impressions."
Here's a copy of a Cliff Stamp post about his tests on INFI's corrosion resistance:
"I examined the corrosion resistance of M-INFI several times and each time was impressed with the results. The first time I just left the blade covered in a 1/2 litre of water for 3 and a half hours. This however failed to induce visible rusting or make any impact on the slicing ability. Making the environment a little harsher I put it back into the water and poured a tsp of salt across the
blade. Five and a half hours later the blade was examined and a three very small rust spots were found, being about 1 to 2 mm across. The edge did not feel significantly different. Ten hours later the blade was examined and no additional rusting was evident. The slicing ability still had not significantly degraded. All rust was then removed easily with a Scotchbrite pad and the edge restored to the x-coarse finish.
Making the environment a little harsher and including the TOPS Steel Eagle for reference
(1095), I put both blades in a steel pan. Each knife was covered with water (3/4 litre) and 2 tsp of salt was poured along each blades. After five hours the TOPS blade was covered in rust along any non-coated area (as expected) and the slicing ability of the blade was cut almost in half. The edge on the Basic was not effected and the blade showed little effect from the soaking except for
a few light rust spots along one side of the bevel (the side facing the metal pan). The rust on the Basic was removed when the blade was dried, the only resulting effect was a few water spots visible along the bevel. The TOPS blade still had rust remaining after drying (much was removed though) as some parts of the blade are engraved and ground out (blood groove and such) and escape contact while drying. Interesting enough, the TOPS blade formed a lot of black rust as well, this was not present at all on the Basic. After drying the blades were again exposed to a corrosive environment.
This time determined to effect the Basic I poured a mixture of salt and water (2 tbsp per 8 oz) over each blade, put both in the metal pan and then added an additional 8 oz of the salt water. This left the blade exposed to the air as well as the water and I hoped the movement of the air would induce
rusting faster. After 4 hours I checked on both blades and this seemed to be evident. The TOPS blade was again completely covered, with corrosion, mainly black rust though as I never removed much of it from the last soaking. The Basic had some spots along the spine and the bevel. When the cutting ability was checked a significant difference was noted in both blades.
Based on that it would seem to me that you would need a fairly corrosive enviroment in order to worry about functional degredation due to rust. I have not seen any in actual use. When it thaws here I will lend both Busses to my brother as he frequently goes saltwater swimming."
http://www.bladeforums.com/forums/showthread.php?s=&threadid=135237&highlight=Stain
Here are Jerry Busse's Own Words about INFI's corrosion resistance:
"Stainless? Not supposed to be. However, INFI has demonstrated very high levels of stain resistance in many different climates. Uncoated blades have been tested for more than a year in Alaska and have made their way into the wilds of British Columbia, the High Sierras and the tropical rain forest. No rust in Alaska or British Columbia! No rust in the High Sierras, even when exposed to great quantities of blood and left in the wet grass overnight. The tropical rain forest, which has been known to rust plastic (just kidding), did offer the toughest of the environmental exposures and a light speckling of oxidation did occur but was easily removed in the field with a hand rubbing of sand and water. No pitting was reported. Now I'm sure that salt-water exposure would offer some different results. The point is that although INFI is not a stainless it is certainly not a rust aggressive steel as many of the high carbon steels have proven to be. Couple this with our coating and you've got yourself a fairly
maintenance free knife."
http://www.bladeforums.com/forums/showthread.php?s=&threadid=187207&highlight=Stain
And here is a post from Climber that--while not based on testing--may shed some light on INFI's corrosion resistance:
""Some Technical Details...
Although INFI is not considered "stainless" by the arbitrary standard by which metals are judged, which is "higher than 15% Chromium" or "higher than 14.5% Chromium" or "higher than 12% Chromium" or whoever you're asking... Yet it DOES what "stainless" is SUPPOSED to do: Retard Corrosion. What really makes something "stainless" or stains less than standard carbon steels??? A good amount of FREE Chromium is ONE method, the most common. Free Chromium inhibits bonding by "outside influences" beyond the metal matrix itself. But to GET to that stage where the Chromium is "freed up" ah, there's the rub. Carbon "locks up" 17 times its weight in Chromium, under normal circumstances, & no other factors involved; which there sometimes are... (Hey, you want a SIMPLE answer? Then ask a simpler question! Ha, Ha! )
So if a steel has 1 full % of Carbon, it would 'normally' require 17% of Chromium to bond with the Carbon, producing Chromium Carbides -- good hardness qualities, good wear resistance, good toughness as benefits --BEFORE any FREE Chromium can do any real benefit in the 'stainless' or Corrosion Resistance department. 440C is around 1% Carbon, & usually 18% Chromium; hence it is a good corrosion-fighter: It has at least as much "remaining" Chromium after Carbon-bonding as there was Carbon to begin with...
An effective ratio for Corrosion Resistance.
Some others, like D2 are less in Chromium (14.5%) & more in Carbon ~1.4%, so it has far less corrosion resistance: i have a D2 sword rusting away right next to me here, just from the humid Nebraska air... (it's an handmade experiment, OK? )
So 'steels'(NOT!) like Stellite, Talonite, & BDC, have a Cobalt Matrix, TONS (Well: 28%-32%) of Chromium! Corrosion-Proof? Time will tell, but it probably will not tell in our lifetimes! Now, if you complicate matters, & i hinted that we would, add a little Vanadium to "THE MIX" and the Carbon is all over that! It bonds well to Vanadium, and it bonds well to other elements. So that decreases the amount of Carbon that is bonding to the Chromium, thus freeing up them little Chromium guys to "patrol the borders" if ya know what i mean! (Cor~ Res~) So also an amount of Molybdenum "frees up" Chromium, keeping them little greedy Carbons from sucking up all that Chromium!
So, Now, lets look at INFI: REALLY look at it...
This stuff is DESIGNED TO BE AMAZING, and it is amazing: here's just part of why:
INFI has less than 1% of Carbon, about half a percent actually; & 9% Chromium. Do the Math: 0.5% Carbon bonding with 17 times its weight of Chromium = 8.5% Chromium used as Chromium Carbides, leaving a remainder of 0.5% Chromium; which is as much as the Carbon was to begin with: so, same RATIO as 440C, a known, proven "Rust-Fighter." Also, wouldn't you know it, there's Vanadium AND Molybdenum AND Nickel AND Cobalt in that thar piece of INFI Steel ! So, there's actually a LOT more free Chromium runnin' 'round the Matrix than our math-formula suggests, as Carbon atoms bond with those other elements.... "
http://www.bussecombat.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=000399
