Been there. At that point you might as well throw the knife away, and start on a new one.Doing a search on the subject within this form it seems for oil hardening steels 1mm is probably a good safe bet. If you want to find out what the limit is grind thinner until you experience bacon edge then you will know for your situation what you can get away with.
Yeah … this is real. Ive been looking at building a wood fired oven for baking hearth breads, pizzas, and other general cooking/baking. These ovens, especially the bigger ones, have a LOT of thermal mass, and stay hot a long time after the fire is out and the entrance is closed up.I'll take your word for it if you say you can hold at 400 degrees for 2 hours , but I'll be honest you would have won every dollar I had in my pocket.
Makes sense. You have a smaller beehive oven. The data i quoted was for, i think, a 40 inch double insulated build that also had an outer masonry shell. Those babys stay hot for DAYS…I'll take your word for it if you say you can hold at 400 degrees for 2 hours , but I'll be honest you would have won every dollar I had in my pocket.
Nice oven. Winter storm here in MN today. Good day to be inside and bake …. So just started up a loaf of sourdough bread. Could use an oven like that to bake it. But wait, it IS snowing outsideI'll try and post a few pics
In the frozen tundra of minnesota?. He** no. Maple, oak, some walnut, ashdo you have mesquite there? thats a kind of wood I use
If you please look again at my post .... I was talking about (and citing data from) somewhat bigger ovens .... mostly just trying to make the case that what docmott is saying is not totally out of the question. I do agree that his smaller "beehive" design oven looses heat faster .Cushing after reading your post I was thinking yep I'da lost my money but then docmott says he puts blades in at 475 , so temp ranges 475 to 400. That's not holding 400 for 2 hours in my eyes , to much temp variation.
Like Stacy said the cost of actually running an electric oven even with high electric cost is not much per blade. If you heat treat multiple blades each time you turned oven on it would be even cheaper. Electric oven for the win.
If you want a cheap option for an electric tempering oven there are some here that use a modified toaster oven, a forum search should give you some ideas.
actually, with the basic design of his current oven, he could take the dome off the base, add a layer of refractory brick, put the dome back on, then cover the dome in a layer of refractory blanket with stucco on the outside. my guess is that *that* oven would then cool much slower than the current one.Cushing after reading your post I was thinking yep I'da lost my money but then docmott says he puts blades in at 475 , so temp ranges 475 to 400. That's not holding 400 for 2 hours in my eyes , to much temp variation.
I got thatIf you please look again at my post .... I was talking about (and citing data from) somewhat bigger ovens
He can do it any way he wants and I am going to sleep the same. The way I read it though the reason he wasnt using electricity was he thought it would be real expensive per blade, even with high electric cost thats just not true. I always thought shop talk was about helping people make the best blade possible , if you read a thread tomorrow where somebody is asking how to temper a blade would you ever recommend doing it in an oven with a 75 degree temp swing while tempering ??The argument about electricity use might be correct .... but it might just be that he wants to try it this way ..... and I personally feel we should not actively dissuade him.
