38.84 cents per KWH.so far ive done 2 batches of knives in the oven. the first was kinda learning, I wasn't sure what was going to happen. the first attempt I made the temp a little high expecting it to lower some. it didnt. so first batch and 2nd tempering I let it cool to a hair over 400dg. closed it up and checked every 20min or so. after 2hr the temp was just the same. I guess it works. on the 2nd batch of knives I let the fire kool to just over 400dg. put them in and closed it up. I checked every 20min or so. all fine. after 2hr I pull them out to cool. put a little wood in the fire, it didnt take much and it was up to 600dg. I busted it up and let it go about 20min and it was down to 400dg. put them in and closed the door. the temp went up a little? not over 450dg so I just opened the door and let it go down to 400dg. closed the door and checked every 20min, it stayed there until 2hrs was up. im just figuring it out. I think the is the rate. for KWH $38.84
ok thanks, I'll keep it at 400475, is starting to creep very close to the area of tempered martensite embrittlement. If there is a chance it will get any hotter than that, i would be very careful of alloy choice, and temperature.
TME starts at 575°F.475, is starting to creep very close to the area of tempered martensite embrittlement. If there is a chance it will get any hotter than that, i would be very careful of alloy choice, and temperature.
Everywhere i see states for these steels right around 500 is when tempered martensite embrittlement starts. Maybe just under. Ive seen it nicknamed 500 degree embrittlement.TME starts at 575°F.
A 475° temper will not approach TME.
However, the drop in the tempering curve for 1095 is right at 450°. It is Rc62 around 450° and drops about one point more at 475°, then starts dropping faster.
I use 425° for 1095 and get around Rc 63-62.
All the above assumes that it was fully and properly heat treated before tempering. If using a forge don't expect these results.
It wont destroy a blade, but a blade that is softer, and less tough. I think i would consider a worse blade than one not suffering from tme.We are talking about martensite, not bainite. Tempered MARTENSITE Embrittlement,
Also, TME is a time function as well as temperature. It takes longer soaks (over one hour) to even start TME. It doesn't destroy a blade, just lowers the toughness.
Yes, I see some information that TME stars as low as 480°, but for practical purposes, it takes more than that temperature and longer time to get a significant amount. One reason I recommend rapid cooling from temper is it tends to reduce the effects of TME.
Perhaps Larrin will chime in with his POV.
