How fine is the line between a saber and scandi grind?
By "zero grind" I believe the term references the fact that the primary grind is "brought to zero" (think like ground zero or descending floors in an elevator--the primary bevel is ground down until it is fully apexed) rather than being interrupted by a secondary bevel.
I have to start with the fact that I´m no expert so take what I have to say with a pinch of salt ,,
A Scandi zero grind is just that , no microbevel , but in order to achieve that and still have a strong
edge you will have to take the sharpening to a very high grit , basically mirror , one way to get around that is to sharpen
the edge to a lower grit , and then put on a high grit microbevel .
Now the reasoning behind the above is very simple , when you sharpen an edge you get striations ( think micro serrated) ,
and those striations may result in chipping , to avoid this you either go the high grit way , and end up with a very shiny
edge , or you go the lower grit way , and end up with a shiny microbevel .
Personally I prefer the high grit very shiny blade with a micro-microbevel thrown in just to be sure.
Oh and I think that this kind of edge is best done in carbon steel , not stainless , it chips easier in my experience ,
and also the height (and blade stock thickness of course) of the grind plays a big part in how sturdy it will be , the lower the sturdier & less prone to chipping but it will not cut other materials than wood and such as well as a higher grind because of drag , so check the grind height and decide on what you´re gonna use the knife for before purchasing , the Sami people historically have this covered by having two or more knives with them.
1234,,,,:)
@ Farmer Ted, Since nothing in this thread has been clarified, at the very least, a big welcome to a new member is in order.
Welcome Farmer Ted.
"Cliff: Shoot.
Bryce: Shoot.
(Farmer Ted points to the Rolls Royce and to Caroline.)
Cliff: Ted, that’s a Rolls Royce.
Bryce: Ted, that’s the Prom Queen.
Cliff: You got two girls in one night.
Farmer Ted: I told you dudes I was hot.
Bryce: Hot? Ted, you’re a legend..."
