- Sep 5, 2005
Emerson Knives makes many if not all of their current blades chisel ground. The reason is found in its FAQ: "A chisel ground knife, being beveled, (ground) on one side only, possesses greater strength, (due to increased cross sectional mass) and they cut with an ease not found on any other type of blade. This is because there is no parasitic drag produced by the flat side when cuttingno drag points. On top of that, they are much easier to sharpenyou only have to sharpen one side."
If they only knew the benefits of such a grind, they say, most knife owners would want their blades chisel ground. But why did they put the grind on the left side? "Our tests and those of a major government agency determined that there was no difference between right and left side grinds for use as a tool or weapon. The left side was chosen for purposes of visual cue and reference."
How many of you have found that this is true? Does a chisel grind on a folder blade affect your decision to buy or not buy a knife? Do you find them easy or more difficult to maintain, and does it really not make any difference which side of the blade is ground? Finally, can you get a chisel grind as sharp as other types of grinds? (I know that my Cold Steel knives can easily slice through leather right out of the box, while many of my chisel grind knives won't.) I once read somewhere that care must be taken with all knives, because even a dull knife can cut a person, but that a sharp knife can cut to the bone. Sounds like a pretty good safety tip!
