As soon as you pull a blade out of the forge, it is loosing heat, and unless your annealing container or quench tanks is inches from the forge, you'll miss your target temp by the time you get there, most of the time by a wide margin. Most everything you do concerning a blade and forging, you will have to compensate one direction or another for the heat loss or gain that takes place when performing given tasks. I'm not trying to be a butthead, its just that in my experience, this is something that a lot of newer bladesmiths fail to realize.
I think Ed Caffrey didn't exactly mean that you would screw up the quench by measuring the temp, but if you're trying to train your eye to temperature, the heat lost while doing the measurement will throw you off. If you want the IR meter to read 1500 on the blade after you pull it out, then the steel needs to be hotter than that inside the forge. So you can't tell what temp you're soaking at by what temp the blade is outside the forge environment, and you won't know how much the temp has dropped, or at what rate.
From 400F to 100F things should be as even and gentle as possible in a continuous cool.
I love this website!
Kevin, I have been working on trying to improve my heat treat consistency over the last several months for O-1...
...Anyone have any suggestions to better my heat treating?
Thanks for a good thread!
--nathan
