Thank you Matthew. I wrote all down and will put it in my grinder and equipment file. It looks like this third wheel setup really tracks well on your grinder. Thanks for sharing your video. Larry
Ohhh I understand now. If you have the hole placed appropriately I wouldn't personally have any inhibitions about that... Only thing is make sure nothing else will get in the way of the full rotation downwards, for me the bolts on the side of the grinder would get in the way.That’s what I meant by drilling Nathan’s c plate. Not using the 1/4 round slot but making another one beneath it.
I’ll get a picture.
Anyone have a good source for the "L" brackets to attach the platen to the C arm? I'd prefer not to shell out $36 plus shipping to get them from Beaumont. I can get some angle iron and fab them myself but just curious if someone has gotten them elsewhere.
Thanks Matthew, I wondered how much I'd have to grind the angle iron to get 90 deg. Sounds like not much.I just made mine from angle, like you suggested. Hysterically, shitty hot-rolled angle stock maintains a better 90° angle than any of the holes drill by Beaumont.![]()
Thanks man. Yeah it allows for quick changes of the platen, of which I basically have 4. 3 will be set up w/ the platen chiller - regular flat platen, 36" radius platen, and end radius platen. Then I have 1 other one that is 1" wide pyro ceram. And also I can have a quick removal for contour grinding w/ no platen.I like that setup you have on your platen Josh, I take it that’s for taking the platen off and putting it back on quickly?
That’s nice.
I’ll get a picture.View attachment 866595
I have run just the single pivot bolt on my platens for years. Never been and issue and you get full rotation.
Might not work for everyone, but it works for me.
That narrow section of belt is perfect for sharpening.
Oh good, I need to get a tool arm from him so I'll get those as well. Thanks Ben!I get mine from Chaz at Knifegrinderparts.com they are tapped and zinc coated. $19 a pair.
