I would add that on a liner lock, liners are very important.
For any reasonable pocket knife task the average pocket knife is already wildly overbuilt (much less Medford-style stupidity).
This is technically correct, which is the best kind of correct, but I would then have to also argue that my slipjoint knives are now officially linerless liner lock knives.
Nope they would be back lockless.This is technically correct, which is the best kind of correct, but I would then have to also argue that my slipjoint knives are now officially linerless liner lock knives.
A quarter inch long fixed blade?oh, and this
Or some other thing which might not be very useful at 1/4 inch length (or width).A quarter inch long fixed blade
How Important Are Lners in a Folding Knife?
Micarta and G10 are equally as good in a linerless pocket knife in my book, so long as they are used properly as folding knives. I think in a very technical sense the g10 will be stronger but for knife use the difference seems irrelevant. I wouldn't think getting one over the other for strength would be worth it unless you just want another knifeI was wondering if the Buck 112 Pro Slim in micarta would need them, the handle feels very light but sturdy when I hold it. I believe I was not used to the light weight and thought it at first needed liners, but after normal use, notice I said normal use, it is just fine. I even though of getting the black g10 version to see if it would be stiffer/stronger. Any thoughts? It is a lock back.
Fiber-reinforced fibers make liners not a necessity, as long as the handle is designed to be robust enough. My Recon 1 is all G10, and it's easily one of the toughest knives I own.
I think it can be hard to escape the mentality of "plastic handles" and be concerned about brittleness or deformation under stress, but I'd challenge you to snap 1/4" thick piece of G10 with your bare hands. FRN and G10 are 100% suited to basically anything but a bearing-pivot knife, and all the latter would require is a metal washer between the bearings and the polymer handle.
But what if you need to stab a bulldozer?
