- Aug 5, 2001
It all depends on HOW it's done.
Agreed, and that's why I said "all other things being equal". And if everything is equal, I would choose a full width tang.
Regarding my bold..........says who?Well, tbh, for a woods gun, a .357 Magnum is more versatile. You can shoot .38's for practice (cheaper) and there are a lot of different .38 and .357 loads for all sorts of things including hunting small game. If you got at least a 5" barrel, you could take advantage of the best .357 ballistics. You can even hunt deer with a .357 that has a 5 or 6 inch barrel, in a lot of states. You can even custom tune hand loads. Can't do that with a 10mm. Hand loads may not cycle the recoil spring if they are a little below pressure.
True story for sure.10mm auto for the win!
Skrama.
Do you know what type of steel that knife was? Just curious. Type of steel and heat treatment do matter some, but yes, I wish Becker would stop putting a hole in their full tangs to "lighten" it. I don't care about the extra ounce or so. It's a stress point, period.I don't totally disagree, however.....a lot depends on how they are made. That goes for stick tang OR full tang.
Stick tangs can be INCREDIBLY tough. I had the unfortunate opportunity (sad/angry story) to take a wood handle off a stick tang bowie I built. I was.....how shall I put it....emotional. I did things to that blade out of anger trying to utterly destroy it to justify completely starting over. I finally took a four pound sledge to the whole thing.....and it still was barely damaged! It took my bandsaw and grinder to ultimately get the handle off. The blade/tang were pretty much undamaged. It was rehandled and finished out nicely.
Conversely, I've seen more than a couple full tangs break rather easily due to holes drilled in the tang or skeletonizing.
I do wish some of these knife companies would stop putting holes in their full tangs" to "lighten" it. It's a damn stress point. They ought to know better.There was a story where someone had to be cut out of a car using a knife.
I think these tests gear more towards a construction knife rather than a bushcraft knife. And they tend to fair a bit better.
The hultafors heavy duty is basically unkillable.
And so it depends what you want it to do.
I just mean that low power loads may not cycle the spring. You may need low power springs. I didn't mean a 10mm can't do everything in the text. Just that you have to be careful with your loads (or use lighter springs. Or heavier, depending on the load).Regarding my bold..........says who?![]()
It was 1075 with tang and ricasso drawn back to a spring temper.Do you know what type of steel that knife was? Just curious. Type of steel and heat treatment do matter some, but yes, I wish Becker would stop putting a hole in their full tangs to "lighten" it. I don't care about the extra ounce or so. It's a stress point, period.
10mms and clip points make my world go 'round.True story for sure.
Most blades that the dude tested break at the blade, not even the tang. Many pocket knives tested don't break at the pivot neither. Bigger knives break more often, all over the place, not just at the tang, because of more leverage, less torque to to flex the blade to the breaking point in either direction. Also, shouldn't the Tavara Skama be considered rat tang? The tang is half width of the blade, the have the blade bare tang for sale.Skrama.
.44Spl is more or less 9x19 in term of energy output. So you are not missing much. 9x19 is much more practical.Good advice! The .38spl was the first pistol cartridge I fired, and I had a good time at it. Would like to try a .357 next! Love the variety of that revolver, though.
Wonder why the .44spl did not retain similar popularity, never fired it, would like to, though, and compare it to .38/.357
"I wonder why the BD1 lost popularity after BD1N, it's kind of what AUS10a was to AUS8a, but we see lots of new AUS8a!"
Starting to see how these breed so many crossfans, disregarding more obvious reasons, haha.
That has some decent toughness. Not a bad steel at all for Bowie knives.It was 1075 with tang and ricasso drawn back to a spring temper.
I agree. I would even say toughness is better than decent. It's probably near the very top of the list for knife steels.That has some decent toughness. Not a bad steel at all for Bowie knives.
This is misleading, as a larger slower round can transfer more of its energy TO the target, rather than wasting a sizable portion BEHIND the target due to overpenetration. This is accomplished by spending more TIME inside the target, with the larger surface area creating more drag, for a more intimate interface. In addition, all things being equal, what a 9x19 might miss by a millimeter, the .44Spl would still nick..44Spl is more or less 9x19 in term of energy output. So you are not missing much. 9x19 is much more practical.
Hmm, the energy output here has more to do with the recoil than stopping power, which has more to do with the feel of shooting than what you are hitting on. There are 9mm revolvers, they are not some rarity.This is misleading, as a larger slower round can transfer more of its energy TO the target, rather than wasting a sizable portion BEHIND the target due to overpenetration. This is accomplished by spending more TIME inside the target, with the larger surface area creating more drag, for a more intimate interface. In addition, all things being equal, what a 9x19 might miss by a millimeter, the .44Spl would still nick.
Ballistic performance and terminal performance are related, but there is no universal correlation. I'd rather have a .44Spl than a 9mm if my target was a 325lb black bear. Leakage is good, but leakage isn't everything. A bear doesn't KNOW he's just been shot with a 9mm, and is supposed to fall down dead. You hit him with an ice pick, and he barely felt it. There is a REASON why hunting guides carry a .45-70 instead of a .308, or even a 10mm Auto with even more rounds. Energy transfer is the key to stopping power. And larger rounds, in general, transfer more energy per round. None of which matters if you miss.....
I'll take ALL THE REVOLVERS. I mean, hey...if you're offering!Take your pick, 9mm, .357 mag, .45, .44 mag, 10mm auto.View attachment 1997585
Drop bear I was pretty disappointed with the Hultafors "heavy duty" knife. I use tools for work and although very cheap I used it as intended and had to back off as it was about to go (blade separate from handle). I don't think Joe X is particularly strong bless him! I might try the Bahco "wrecking" knife. For the cheap end of working knives my Moras have for a little more proved more durable than the Hultafors and they are fnished better and have superior blades and handles too.
No, that's not what I meant. The bare tang example is to show the anecdote of tang size and type.Would you want an exposed tang chopper? I assume the reverberation from the bare steel to your hand would be pretty severe.
